Wanted Oil filter Bracket
mico
G'day all I need an oil filter bracket to suit either a Soarer or Celsior
I have a 2uz Landcruiser Bracket (doesn't fit where i need it to sit s further forward) which is brand new that I can swap or will buy if the cost is cheap enough
Soarer and Celsior brackets are different.
The Soarer sticks almost straight out of the block.
The Celsior moves the filter forward and out.
You need to decide just which one you need.
pretty sure you got that back to front the Celsior one sticks straight out and the Soarer one moves it forward (but nowhere near as far as the Landcruiser one it still fits under the A/C pump) and either will do the job that i need, so it doesn't really matter. The Celsior one would be better for access but the Soarer one wouldn't be that much harder to get at and both will fit
Here are two oil housings. The left is the SC400 and the right is the LS400. They are both line up to the bolt pattern. Perhaps J-spec might be different.
Got a remote oil flter at the moment and i can't stop the rotten thing leaking
and i can't get a filter onto the existing (crown) bracket or i would use that
what vehicle is the engine in? i was able to get a filter that wounld fit my hilux 1uz
the engine is in a Hilux, I know that a Soarer one will be all right not 100% sure bout a celsior one depends on how far out the filter sits from the block, what filter do you have on yours?
im using a filter off a john deere ride on mower. i have about 15mm clearance when its on but i do hace to take a bolt out of the idler arm to get the filter on and off
I have one that moves the oil filter to the very rear of the motor, if that helps. You can try it if ya like. I'm in Newcastle aswell.
I also have one that moves it back just a little bit.
