Ok so I have a wierd problem that I have never ran into I have a 1992 Lexus SC 400, the car randomly will let me start it, when it will not start there is no mil in acc or run key postions, I have been told that it could be the ECU malfunctioning, the reason for it not starting is no spark the fuel pump does turn on but the coils are not firing they do have 12v going to the coils. It happens every day I will go out in the morning and be able to start my car it will start as long as the check engine light is on and run fine, after letting it run for a while or driving it I will not be able to restart it, has anyone experianced this type of problem, or is there anything other than a bad ecu the would cause the check engine light not to light up when the ign is in acc or run, also what pins do I have to jump to get a code so the next time I can get it to start I can pull codes on it. Thanks I am new to the forum, the car, and the engine.
