no power???????????????
hiluxmad
melbourne victoria australia
for some reason the ecu wont trigger the fuel pump outputs and there doesnt seem to be any power to other parts afm, ignitors, coils and poss more that i havent found yet but its all hooked up as it should be according to kdogs diagrams and zuffens write up. any ideas guys im stumped i know it has to be somthing simple. BTW it will crank fine but no fire coz no fuel pump. 5volt out put seems to be working. is there a wire ive forgotten or missed?:eek:mfg:
Hiluxmad,
someone correct me if I'm wrong, but there is a common 12V wire that will need to be connected to your ignition - you'll see it on Kdogs diagrams coming off the ignitors and injectors - just pull a plug on an ignitor and look for the black and orange wire - then bell it out on the main loom.
Muzz
is trere a failsafe some where that is causing this? what sends the signal from starter to ecu that it is cranking? would having no radiatoor/no water cause this? oil pressure? BTW 131 crown. any way to test ecu to ensure not damaged?
