G'day all,
i have finished all the wiring and test fired it today. BUT. If i spray fuel into the intake it runs and stops as soon as it has burned up so obviuosly the injectors aren't supplying fuel. Also the fuel pump isnt working through the ecu so i powered it direct to get the fuel up so i do have fuel at the rails. I have obviously missed a wire somewhere but with the limited details that i have i can't seem to find anything. The engine is a 92 model by the plug leads and the ECU has 1 large plug with a bolt in the middle and a smaller plug which seems to be the one with all the power conn on it. There semms to be 2 wires that are for the fuel pump ECU by the pinout diagram that i have but doesn't tell me if they are power from or power to or earth the relay for continuity etc.
Anyone got any ideas or suggestions.
PS i haven't set the fuel pumps with the 2 speed setup. I have 2 fuel pumps, one low pressure to the surge tank and the high pressure one next. Both are wired together.
Thanks
