Hi folks,
All has been fine up until now on my swapped engine, albeit without the lambdas and afm plugged in. I`ve now connected them, but the idle is surging/hunting between 900-1500.
It`s thrown codes 41 (tps) 21 and 28 (o2 and sub o2)
I`ve undone the screws on the tps slightly and played around, at anything other than full clockwise (i think it was anyway) it`s fine, but a very high idle (1500rpm ish)
Removed completely and measured across pin1 and 2, 4.9kohms closed, 625ohms full open, does this sound within spec?
Lambda fault is probably my own fault, will go through connecctions and check as i`ve paired the o2`s and sub o2`s\
Any help will be very much appreciated.
Thankyou, Jay
Thankyou, Jay
