Need info on disabling the fan hydraulic motor.
jibby
Need help on the how to properly disable the oil driven fan hydraulic motor. I have bridged rather then plugged the two hydraulic oil lines coming out of the hydrualic pump at the source near the pulley's just incase I cannot disable.
I want to make sure the ECU does not activate or power on the pump any longer as I would assume I no longer need it with the electric fan... This is on the 1992 sc400. Does anyone have any ideas from experience, maybe just disconnect the sensor? Or should I just let the hydraulic pump run when it wants to, the motor will not have to work hard anymore as the oil lines bridge/loop and flow smoothly in a circle now that it does not have to push the fan.... Here is a pic from yesterday.... Any thoughts on this???? I can really use some advise on this one anyone please?????
Thanks for the reply and glad to see you are still not mad at me, no hard feelings on my end... That is nice work.......what car is that? Crank and alternator very crude.....No power steering, no air conditioning, no fan, no thanks.....
