Low power.
hilux_bondy_007
hey guys, i just had my AFM go on my 1uz so i brought one off ebay from the states. i put it on and now the car runs but seems to have every litttle power. I had a problem like this before, it was only running on 4 cylinders but i changed the coil pack i think it is. on front and back of motor. i was just wondering if anyone would have anymore ideas what could be wrong. i can get video of it runnin if that will help.
thanks Bondy
The second coil is near the AC compressor. I am not sure what u change on the back of the motor. You can check the spark plug and make sure all the plugs are firing. I would also double check the wires and vacuum lines.
i was told by mechainc he changed something at the back. thought he said coil pack. yer i may have a look at the spark plugs and have a look.
i just been playin with coil packs, do u need both in for it to run? i took top one out. nothin changed then took other one out and it wont run?? maybe a noob question but i am new to this.
also, wat size socket do u need to get spark plugs out, i got the one that came with my socket set but cant find to get it out?
If you take the top coil out and nothing change and take the other one the engine dies. Then the process of elimination should tell you which one is bad. The top one is bad.
