lokar Shifter
redsx
anyone fitted a cable Lokar shifter to a A340E? I noticed that MV automatics in south oz have cable brackets for a B&M shifter could they be used for the Lokar shifter.
Lokar have emailed me back saying the detents on the shifter don't line up, yet I have seen these shifters used in a couple of street rods with a 1uzfe and 3 speed B&M shifters work on these boxes. How can you check and compare the detent gate.
lokar
you need to change the detents to suit can be done as mine has
also need to swap the shifter arm from left to right not easy but also achievable as mine is
plugs
almost up and running but seem to have lost the one plug I needed in the maze of wires
I need the 6 pin solenoid controller plug anyone ?
