Ben Thorne
Hi All,
Hopefully someone can help us out with my problem. I have 92 hilux with a 1uz installed it has worked fine until just the other day when the car started running on only 7 pots. Thinking it was bad fuel I drained the tank and put in a fresh batch. It ran good for another day then started to run on 7 pots again. I did a comp test on the engine and they were all over 200psi, I then checked spark and that is all clear. I then got the injectors cleaned and serviced and its not that either. I then found that the injector on pot 2 on the left side of the car doesn't have a pulse, it has power just no pulse. All the other injectors have a pulse and will run and idle the car.
Has anyone else come across this problem? My only other option now is that its the ECU. If anyone has any thoughts please add them.
Thanks again
Thanks again
