Idle air control unit
  • Thread starter Thread starter PM
  • Start date Start date
PM
Hi,
are the IAC units 22270-50010 and 22270-50020 from the later models are interchangeable ?
I don't need the complete assembly, just the black, round motor housing as one of the 3 screwholes is broken.
the plug for the wire is the same ?
thanks
Heiko
If its one of the later model ones that seems to be a cast unit that can't be pulled apart then no, they are physically different sizes, as well as being electrically different.
However I don't know the part number or the year of the later model one I had, I just know it now serves as a good paperweight.
god i threw some out
ive had to fix 5 seized 1uz idle motrs in past year
all the 1uzs at work that are purely for parts have missing idle motors
dont fit a later modle non repairable unit thou
ill back in the shop on fri ill go thru the boxes of spares see if i kept any
sorry for the late reply, been in the us for a couple of weeks.
bought ring & pinion 4.10 for my grand cherokee which works much better with the 1UZ engine and gearbox. original was 3.73 - not good !
anyway , if anybody got a ISC motorhousing. old model 90/91/92. The one you can pull apart ! don't need the motor , bearings , spring etc. just the round black housing as my one is broken at one of the 3 screw holes. glued and siliconed it. don't know how long it will hold .
live in Thailand !
thanks
Heiko
Madmont, that is great to know, will they fit physically (on the plenum) as well as electrically (wiring) on both the older 1uz (1990-1995) and the newer 1uz (the pre-vvti 1996-1998)?
(sorry for the hijack)
Newer ones are NOT electrically compatible with the older ecu's.
hey peewee, do you mean the later VVTI 1uz's (1999+) or the 1995 to 1997 1uz's?
And what models are compatible with the 7mge ISC's (if any...)?
thanks
Nah, the later non-vvti's. They look very similar, but are 2 piece instead of 3 piece, and a little bit larger.
The early ones should be the same as 7mge, never personally compared though.
Will not fit on the plenum but the motor part will fit the housing. plug is the same
