FWIW, I have both SupraTT and 1UZ flywheel, and the SupraTT FW is slightly smaller. I am going to pull the ring gear of the 1UZ FW, the grind down the teeth on the SupraTT FW (on a lathe), then weld on the 1UZ ring gear to the SupraTT FW. Also, I'll have to drill 8 new holes so it will bolt to the crank.
I have not decided what to do about bolting up the V160. I was thinking of either milling the V160 bellhousing flange down 1/4" then using a 1/4" mild steel adapter plate, or picking up a A340 and making a hybrid bellhousing, 1/2 from the V160 and 1/2 from the A340.
