spf_lexus
not to mention the motor would not last long due to the imbalance caused by the dropped cylinders...
Not saying that I dont believe you but can you elaborate on this some? I initially ruled this out as I assumed that the weights of the rotating assembly wont not be changed. Would it matter if I left the plugs installed so that pumping losses stay preserved? Also, a single coil being removed would be 2 cylinders from each bank so the overall drop in usable cylinders would be even from bank to bank.
