Hi all..I'm new here to your forum and have been quite impressed by the members knowledge and feedback given. I hope you can help me as well. I am working on my 92 SC400 and have just completed changing the water pump, timing belt, intake manifold gaskets, spark plugs and wires. I have inspected the distibutor cap and rotors and find them to be OK..no arcing present...but am going to change them as well. The timing belt is aligned currectly as well. The engine started up fine and runs very well at idle. My problem is this..the engine does not want to go over 2800 rpms whether in park or on the road, it begins to feel like it is bogging down. A timing light was used and at idle..800 rpm..shows appr. 7 to 8 degrees, when increasing the rpm, it does advance and at 2800 rpm the timing jumps all over the place including below 0. No check engine light is present and as a check, disconnected one of the cam angle sensor leads to see if check engine light would come on and it did...reconnected and went off. Also, the cat gets very hot.
Before above work..I don't recall having any problems with clogged exhaust or cat.
Thankyou in advance for any suggestions you may all have.
