Cut wire in engine bay
sonyman
I've been having a cold starting problem and wonder if this may be related. I popped my hood today for a routing checkup and noticed a wire touching the serpentine belt. It was cut halfway through. I'm going to have it repaired soon. Where is this wire supposed to be tucked away? The wire is pretty long so I'm not exactly sure. Pictures would be very helpful.
The images are fairly large so 56k beware:
Picture 1
Picture 2
Scott
That wire goes to the coil pack that is in the 1st pick. Normaly it has a clip under the pack that it clips on to.
It is the wire that goes to the cam angle sensor on the left bank
How would this affect my motor's operation if its slightly damaged? The connection is still fine, since when its unplugged the car throws a CEL? Its kind of disappointing that it isnt the connector for the cold start injector time switch since I have a cold starting problem, and I thought this was the culprit. :sorry:
Scott
