KazeSupra, yes, the distance is just fine. The input shaft is at the right position related to the clutch and pressure plate. I have not driven mine yet. but I have assembled it all with a single disc clucth and a ACT pressure plate, which is very similar to the WOTM clutch package.
If clutch masters can make the flywheel for you, that would be the best bet. They already make a 2JZGTE flywheel, so all they need is the 1UZ flexplate with ring gear: they can use that ring gear and measure the specs for the holes to bolt the flywheel to the crankshaft. If I had known they can do this, I would have done that. I tried to get this done with another clucth maker, and I was strung along for 1 year after paying them in advance! I finally got my money back and make my own.
