Hi,
i have a couple of questions regarding wiring.
1/ the black/white stripe wire from the csi (cold start injection) temperature sensor, is this a ignition fed positive or is this wire a ground?
2/ the wiring to the throttle position sensor 2 (i.e the one connected to the opposite end of the butterfly that is controlled by the traction control stepper motor, is this wiring needed at all as there is 1 wire yellow/red stripe that goes to the ECU or will the engine run fine without this wire connected. i assume the blue/white stripe and the blue/red stripe go to the traction control ecu and the brown is a ground
any help greatly appreciated
thanks
John
thanks
John
