Just call me "Lex"
- Messages
- 12,033
- Location
- City of Halos
Anyone interested of making a larger crank pulley for supercharger application. I am looking for one about 7.5".
Andrew the retrofit 8 rib harmonic crank pulley is 5" is that correct? I am interested in the bolt-on because i can run much higher boost like 17-23 psi.Richwood said:We are as we speak making a 8 rib harmonic/crank pulley, plus pulley's for all the accessories, it will be a retro fit, replacing the 6 rib, for those wishing to run higher boosts, the problem we found with the seperate drive apart from crank snout load was room in the engine bay, further problems being the support rib under the bonnet, in some cases this had to be cut out, depending on supercharger pulley size, supercharger type and manifold height. Andrew
Hi,,, do you have any specs on a supercharger for 93 sc400,, iam trying to locate someone that could make all the brackets and piping,bango said:Im In for one,iv got a hold of a twinscrew off AMG e55(Good price too),my next thing apart from the manifold was the pulley,add on is what iv come up with too..
