Clutch help
ruishy1
ive mated a 350z box to my 1uzfe, ive got an mr2 flywheel to use as a base to ahve a custom steel one made.
What im thinking about is clutch's
Sould i have the flywheel drilled for 350z clutchs, or get something else made up ?
The problem with 50z ones are the price, for a stage 1 its about 700 GBP and with an aim of 600 bhp it wont cut the mustard !
any ideas or tips on what would be better suited ?
Extreme Performance Flywheel which is drilled to take an R32 GTR Skyline clutch cover and done. Use them in the 4wd Hilux swaps with the GTR Cover and 'Cruiser clutch disc and release bearing. In this instance I'd think you could use the afore mentioned flywheel (Which is designed for motorsport use) and it should open up a lot more options for you
