Hey Gang,
I have been working very close with my engine builder and research on my own. The 1uzfe stocks are very strong already with 6 bolt main, its almost bullet proof. However, our stock pistons are really bad. Most of the problems with the first generation pistons are the ring lands. I have personally seen few engines with the same ring lands crack pattern.
Anyway, make long story short. I have been reading and matching off the shelf products from the domestic arena. Here is what i found.
Chevy Rods:
Large journal 2.100"
Piston Pin = .927"
Rod length 5.7"
UZFE (All uzfe engines):
Crank End (big end) Diameter 2.165"
Pin End (small end) Diameter .864"
Rod length 5.7455"
As you can see the numbers are pretty close. The Chevy larger journal is about .065" smaller and the pin size is .063 larger and the rod length is about .0455" shorter. The rod length and pin size is not an issue. Custom pistons will take care of that.
The Chevy rods are dirt cheap. Forged H-bean rods capable of handling 1000 hp is about 350 usd. Here is the solution:
1. Machine .065" off the 1uzfe crank
2. Get a set of custom pistons to make the whole thing work. The custom pistons also use chevy pins. Machining .065" off the crank is no big deal. Chevy have smaller crank than uzfe and they are making huge power. Machining that little amount would not be a problem at all. Since the crank is machined to Chevy rods size, then we can use chevy rods bearings too and they are also dirt cheap.
What do u think? Here are some pictures of 1uzfe and 3uzfe rods:
Here are few pictures of H-bean Chevy rod. The first rod is from Eagle and the second rod is from Scat.
Boy, with the above combo..... you save money on parts and you will have a bullet proof shortblock.
Chevy Rods:
Piston Pin = .927"
Rod length 5.7"
Rod length 5.7455"
