B25
- Messages
- 17
- Location
- United States
hey!
I recently bought a first gen 1uzfe from a local U pull it for a project.
I have almost no experience with the engine, but I did notice that I could not turn the crank (from the bolt on the front pulley wheel) by hand.
I thought it could be because the timing belt was cut (but still on), and when I turned the crank, it wasnt turning the pulley wheels on the head, since the timing belt wasnt turning them with the crank.
I thought it might also be because the torque converter was installed.
it is worth noting that I was able to turn the crank about 5 inches, but then it would become much harder to turn, and I was unable to turn it further. the first time I did this, some sort of fluid (oil?) bubbled up one of the intakes on the inside of the heads (the ones that the throttle body channels into).
I am posting this because I am worried that the engine has some sort of damage that I am unaware of (since it's from a U pull it style yard).
why cant I turn the crank by hand?
sorry if this is in the wrong section
sorry if this is a dumb question
thanks!
thanks!
