D dass New Member Apr 27, 2006 #1 Anybody else had the problem of not being able to fit the cam drive gear over the new camshaft without machining a piece out to clear the lobe.
maajola New Member Apr 30, 2006 #3 If you have camshafts with hight lift (~10mm) you will have to grind/machine the center gear to get it on. dass said: Anybody else had the problem of not being able to fit the cam drive gear over the new camshaft without machining a piece out to clear the lobe. Click to expand...
