Hey all.
Have a few quiky's
I'm currently trying to decide whether I'll have the superchargers mounted low down on the sides of the engine or high up next to the cam covers.
High Pro's
no interference with the engine mounts
short intake length aids throttle response
looks nice
High con's
Longer belt runs unsupported
lot's of heat from exhaust system put in the chargers
Higher point of gravity (8.8kilogram each for the M45's)
Low Pro's
virtually No heat from exhaust into chargers
keeps engine smaller on top
shoter belt runs and doable with stock pully/belt route
Low con's
interfere with engine mounts unless I place them further outside the center line of the engine or incoorporate the engine mounts in the sc mounts
little more volume in intake system so less throttle response
Lower center of gravity.
Oil filter needs relocating
The thing is how long can a correctly adjusted (tension) belt run, unsuported by aditional tension pully's, Would 35cm be to long?
ofcourse any comments on the set-up much appriciated.
Grtz Thomas
Have a few quiky's
High Pro's
looks nice
High con's
Low Pro's
Low con's
Grtz Thomas
