Another Bushes Success Story
vlamos
----- Original Message -----
To: Andrew Vlamos
Cc: [email protected]
Sent: Tuesday, May 25, 2004 1:43 PM
Subject: RE: Vlamos Bush Sets
Hi Andrew,
Everything worked out beautifully !
BACKGROUND:
A couple of weeks ago my car had all its original suspension (and steering
rack) bushes from 1992 - except for a set of cheap-n-nasty blue nolethane
bushes up front on the lower control arms. The ride was OK, but I always
suspected it was too 'bouncy' - minor bumps in the road would cause the nose
of my car to move up and down more than normal. When my wife was in the car
she would indicate this to me by nodding her head back and forth. She was
right though, her new Mirage had a smoother (and quieter) ride than my
little baby. In addition to the bounce, my suspension would occasionally
creak and groan when going up gutters or over speed bumps - more noticeably
when it got cold, and Canberra's winters get bloody cold (it was like my car
had arthritis).
ACTION:
First step was to take care of both stabiliser bars so I bought (and
installed myself) two front, and two rear, D-bushes from Toyota. This
actually made a small improvement to the ride quality and reduced (but
didn't eliminate) the suspension noises. Second step was to take care of
the steering rack so I purchased two of your bushes and bought the third
'grommet' bush from Toyota. These three bushes were installed by Neil
Griffiths along with your control arm bushes. The install of these bushes
made a noticeable improvement to the car's steering - there is now less
'play', it is also much smoother and more responsive, and shocks from the
road are absorbed more effectively. Final step was to take care of ALL the
control arms (ie. front/rear, upper/lower). The installation of all your
control arm bushes was where the greatest gains and improvements came from -
as indicated above these were also installed by Neil.
RESULT:
What can I say ?, "THANK YOU". NVH levels inside the car have been reduced,
body roll when cornering is not as noticeable, there is less squat/dive
under acceleration/braking, bounce at the nose has virtually been
eliminated, and there are NO noises/eeks/creaks/squeaks/clonks or donks
coming from the suspension when I go over (speed) bumps, gutters, etc. Most
importantly, the ride quality has been significantly improved (as if the car
was brand new), she now feels more stable on the road, and the increased
enjoyment and satisfaction I obtain from driving her now is more than I
expected two weeks ago.
The investment in your bushes has been worth every cent and I would not
hesitate in recommending them to anyone. Keep up the good work Andrew - I
look forward to your future products and releases.
Best regards,
Ron.
PS: A big thank you to Neil for installing everything in one day - I know
your level of workmanship warrants no questioning.
_____
The bushes for the LS 400 are currently being produced will ahve them available by the end of June (hopefully) if all goes well :-)
Andrew,
I am definitely a believer in your product , but would love it if the Celsior/ LS 400 crowd had the option to address the "bushes" in our steering system. The sloppiness in mine compared to a GS 400 is apalling!!
Thanks
do any one know . the air suspension 's height can be control inside the car? Celsior is so low and 'soft', always hit the front lip. hhow can i make the car higher and the suspension not so soft!
Are we gonna be able to buy Andrew's new LS bushes separately? I probably wanna get the bushes for the rear axle carrier separately along with steering rack bushes if available, since I've replaced the front and rear control arms anyhow.
Thanks.
SO, um, where the hell are these vlamos bushings for the LS400 we were told would be ready, cuz im ready to order, and he hasnt emailed me back at all, nor has any new info been posted....
I want my car to stop making all these noises and I want my ride to be nicer. Im running Tokicos and Eibach springs... and Its too rough with my 14 year old bushings.... I want those bushings already.
So any word on a bushings set for the gen1 LS? this thread was really interesting then it just kind of ended. I'm considering changing all the bushings out in my car, so I,m looking for an intire set, rubber or eurathane.please help.
What about the (Aristo)GS 300 95 model
Does anyone know what bushes they take
Could they be the same as the Soarer
