Hi Guys,
I'm in the process of making an adapter to go between the 1Uz-fe A341 trans and my duel geardrive Hilux transfers, with the intention of making 10 of them to sell. I need a bit of info regarding the speed sensors, but more of that later, heres a few pics of the progress so far,
Let me know what you think of the design. It will bolt directly to the back of the Lexus A341, you will need to cut the thread of the output shaft of the trans.
It will have a double row bearing that the spline coupler runs in and a new speed sensor trigger. A Lip seal is behind the bearing so trans fluid doesn't leak out into the adapter, and an o ring inside the coupler. I will be designing a version of this that has a PTO unit incorporated in it that uses a synchro hub out of an old transfer case, more of that to come
Now the questions regarding speed sensors....
This is a pic of the trans with the tailhousing removed, you can see one small speed sensor and the speedo drive still attached to the loom, I want to know if all will run properly without the speedo drive?, ie is there a speed sensor in the speedo drive? or does it just use the small one on the opposite side?
Can i ditch this altogether?
Next question, Is this gallery and hole to supply oil to the rear bearing?
