2UZFE coil wiring loom
autronic
Does anybody have the coil loom for the eight coils on the 2UZFE engine, or does anybody know if it
is possible to just buy this from Toyota ?
Autronic, according to the Toyota 2UZ wiring diagram, they have 8 ignition outputs going to the coils. Is that what you've planned, or are you running waste spark? I suppose even if you're running waste spark, you can pair up the coils at the end of the harness?
I'll contact Curt @ Elmhurst and ask him if there's a separate coil harness for the 2UZ in the Tundra.
Maybe Tundraeddie will chime in here, too.
Curt says it's a complete engine wiring harness, ie ignition, injection, sensors, etc. with an ECU plug on the end.
I was able to get the harness side coil connectors thru the dealership (with pins). I will check the part numbers and post them when I return home in a day or so...
