I was looking at the tundra solutions site and noticed that tundras do a base dyno of around 200-210hp, while the 1uz does around 180, right? Isn't the iuz rated at 250 crank hp and the tundra 235hp, also the 2uz makes the peak way lower in the rpm range as a truck should.  I wonder the differences in the cam specs on between the engines and if the valves are the same size and overall head design.  I think JBrady felt that the 1uz is really around 230hp which sounds about right considering dyno results.  Some have mentioned installing 1uz head on a 2uz for an ultimate flow combo, but does the 1uz head, really out flow the 2uz head? At this rate the 1uz makes slightly higher horsepower per liter than the 2uz, but not much and i wonder if that has more to do with higher compression ratio, thoughts?
