200 pound DOHC V8
JBrady
Houston Texas
Interesting:
http://www.h1v8.com/page/page/1562069.htm
SPECIFICATIONS H1V8:
75° odd fire V8
2.8 LITER, 170 cu. in. displacement (3.0 liter optional)
84mm Bore X 63mm Stroke (67 stroke optional)
4 cams, 32 valves via internal silent chain
530mm wide x 485mm long x 530mm high
400HP @ 10,000 rpm with stock street cams (higher spec. is available)
245 ft-lbs torque @ 7500 rpm
200 lbs engine weight
Billet nitrided steel 180° crank
4340 H-beam con-rods with ARP bolts
Billet 6061-T6 aluminum crankcase
Dry sump 0il system with 4 stage pump
7.25" or 5.5" Twin disc clutch
DTA S80 full sequential ECU
Unique cylinder offset and cam drive arrangement yields a compact design- Patent No. 7,168,405
I saw an Atom on the road near Oban on the west coast of Scotland a while back.
Absolutely insane.
I'll have one or two thanks.
Unfortunately they can't be registered in Australia. Allready checked!
