Yes, it fits but you would need the rest of the 2UZFE intakes to make it would. The head angle are slightly different. The 2uzfe or Vvti engine lower intake is almost horizontal vs. 1uzfe is slightly angled.
monaro-azz said:So is the answer yes you can use 2uz heads on a 1uz block? as long as you have a method of controling the advance/retard on the cams? as i have a pair of vvt-i gs400 heads and manifold which i was going to use on a vvt-i motor, but i have since found out that the vvt-i's have the weaker rods so i now want to use a 1uz and fit the 2uz heads to it as i will be supercharging it. Is it possible? is there a difference in the bore size between 1uz & 2uz?
WDoherty said:So since i imagine that the 2uz head flows better than the first gen 1uz head and this would explain the power and torque that motor seems to make including the .7 liter advantage even without the use of vvt-i. Therefore, the 50hp jump from the 1st gen 1uz to the 98-up is not soley from variable valve timing, but higher compression, and better flowing heads and intake manifold combined? Yes?
