Aussie Drifter
- Messages
- 42
- Location
- Victoria, Australia
Hi guys
I have finally got my supercharged drift car going. I entered it in a Drift practice day yesterday but I was unable to make power over half throttle. I tried everything that I could at the track including changing plug gap and coils with no success. The car seems to go better when it is cooler and gets worse as the temps go up. The engine temps seem to hang around 90deg so it isn’t excessively hot.
The first few outings the car went like a dream and had full power all the way through the rev range.
I am running a 2.3L Wipple pushing 12psi, with an Adaptronic ECU calling the shots. This is the 3rd engine I have had in this car, with the first one being my fault, the second giving up the go on the dyno (with the same rev type issue as this one) and now this one is not playing the game!
I put the second engine down to not having a big enough exhaust, Stock Log type into twin 2.5” with a “Y” into single 3”. (Stock Log type is all I can fit at present.) But when I went to the 3rd engine it seemed fine with the small exhausts, well until now! (I plan to cut the chassis rails out over X-mass so exhausts will not be a contributing factor any more.
Any thoughts on what the issue is? Or what I can check for?
Thanks in advance.
Adam
Thanks in advance.
Adam
