Trade 1UZ VVTi / 3UZ / 2JZ stock ECU conversion for M/T
George_R
Well-Known Member
Staff member
This offer is a device that eliminates limp home mode, which is otherwise active if ECU does not 'see' stock auto transmission.
Earlier ECU models (1UZ non-vvt, 1jz, 2jz before 1998) didn't have "underpowered" fuel/spark/vvti (for the JZ) maps for N/P transmission range, so these ECUs are 'fooled' quite easily.
Newer ECUs are not like that. Putting them in P or N will eliminate all fault codes, but engine power will be somewhat limited.
My device solves the problem by simulating solenoids and input/output shaft rotation sensors, so the speed of 'rotation' corresponds to engine RPM and current gear.
The only dyno sheet available so far is for 17x body Toyota Majesta engine in a 90-series MarkII
It's not perfect and the 10% lack of torque can be explained by non-functional variable intake geometry system (ACIS)
The device costs $100 USD shipped worldwide
It will operate of course
With my device, ECU thinks it has its stock a/t and performs accordingly
It's test car problem, not related to my device
Used ACIS control solenoids don't last for long. The owner didn't want to replace it with a new one
I see. Is it possible to plug your device into the tranny wiring harness? I'm still phobic about cutting up my ECU wiring harness.
Possible but correct operation is not guaranteed with long wires
You can just undo loom pins from connector so the operation would be reversible
Or buy a modified ecu from me which will not interfere with a/t loom
Yes always available, works with GS430 ecu for 5-speed auto. 6-speed variant is under test now. Price 100 usd shipped. PM or email me for details
George, someone emailed me asking if this is still available. Also, would this be described as a "transmission simulator?"
well a lot of things happened
the device exists for 1uz vvti and 3uz 5 speed ecus
all4swap.ru/product/atemu
Also, any 3uz ecu can be remapped for various goals, including conversion to m/t .
This service is available in Russia, UK, USA, SAR
