1UZ throwing code 56 (hydro water pump)
WAS200
Hi people, I have a 1UZ which is in a conversion. Its front sump with the hydro water pump. I swap the water pump to a belt drive and now its throwing code 56 (which is the hydo fan bypass)
The car revs freely when its first started but then throws this code and then hunts (revs raise and drop) Any help would be appreciated
Thanks
Thats right was hydro, now non hydro.
No seperate ECU.
No body knows how to bypass the hydro wiring in rder to stop throwing this code?
Samsdad, I dont know what you look like or am I into men but I could kiss you :tongue:
Much appreciated..
G'day
Having a problem with this code 56 in my 1uz hilux. The link that samsdad posted takes me to an unrelated thread about a trans issue.
I found another post that recommended grounding pin 1 of the 4th connector, no luck.
any help would be much appreciated
cheers
dave
Do a search regarding hydro fan level
There is afew things u need to bypass on some celsior ecus
Much easier to not hook up check light
If engine runs fine then I wouldnt worry bout code
I've only had to trick two ecus
Everyone else ran fine
