sump
the sump is made out of 3mm mild steel has been well baffled 5l capacity was originally a mid sump engine the original one sat right on the cross member we used a heavy duty mr2 turbo clutch kit the thrust bearing from this kit did not work so we used one from a commodore rb30 engined one got 2mm i think lathed out so it fitted the toyota shaft running a link v5 ecu bosch 910 + vl comodore turbo fuel pumps surge tank
