RedPhoenix
Hows it coming
And what are your plans with the lower intake manifold? Very curious about that (not to throw this off topic).
Looking good mate. Hydraulic throwout for the clutch i assume looking how tight it all is?
Matt, its going slow as usuall. Im probably going to be finishing the final things on the Left header and starting the Right header this weekend.
As for the manifold, it will be just a single plenum, short runner manifold, with forward facing TB(s). Either duel individual TB's or a single with duel butterfly's haven't figured it out you. I haven't figured out all the details as of yet but It will be something along the lines of the attached photo just to give you an idea. I am toying with the idea off doing it out of stainless steel of ceramic coated mild steel. The reasoning behind using steel insted of aluminum is far less heat soak and thus cooler denser intake air which would equal more power.
cool beans, where's the flex joint going?
Congratulations on finishing this part of your project...
Now get the rest of the project under power!
Any plan to make some for our members?
