1UZ into 60 series landcruiser
hiluxmad
thought i would put up my current project
60 series landcruiser with rust removed.
I am starting to think that rust was standard from factory in these things.
while the cab is off i am fitting the 1UZ to the standard 5 speed box
used a castlemaine kit that i have had for some time now and made a 10mm spacer to stop the input shaft hitting the crank.
it will be running a dyna clutch.
made the engine mounts the other night. used some holden to chev adaptors i had in the shed modified them to bolt to the toyota block.
they look like this:
then made the chassis mounts from 50x75x5mm RHS and plated 2 sides of the chassis with 5mm angle and finally gusseted it with 5mm plate for strength.
Looks the goods mate, should be a nice rig.
A mate of mine has a 60 chopped into a ute as well, it is sprung over on 37's.
did the rear spring over this afternoon looks massive now.....
makes working on the chassis easier tho!!!! lol
pics to come next coupla days.
