1992 Lexus SC 400 Neutral safety switch Part # 84540-50010 discontinued
DaveC
1992 Lexus SC 400 Neutral safety switch OEM Part # 84540-50010 is discontinued.
1995 Sc 400 (NSS) OEM Part # 84540-30270 is available thru Lexus/Toyota. is this compatible, as I would rather to use OEM.
David
Yes, I would be fine with using the second one, if fact its my preferred item with a replacement connector as connector is different, but switch operates and fits transmission fine
1. Just to clarify 1992 -1994 Lexus SC 400 OEM Neutral safety switch is discontinued,
2. 1994 Lexus SC 400 OEM Neutral safety switch part # 84540-30270
3. Since my last post after research ,the OEM Housing connector is part # 90980-11332 for the 1994 ,which is different from the 1992- and requires to remove the wire pins from the old connector and insert into the new housing connector was then also looking for info/diagram for the wire color and positoin to insert into then new style OEM connector, sorry I should of posted sooner.
I did this exact job the other day. As part of my wiring instructions which I sell I have this info, but even without any info , having a basic understanding of the components allows the job to be completed with ease.
