1988 Cressida 1995 LS400 1UZ Swap
88sogreatv8
So I have been slowly working on my 1UZFE That is going into my 88 Cressida.
I am to the point where i am working on the harness .
I would like to make it plug and play , so i just plug in a few body plugs and hook up the grounds and powers and go.
I am on the E11 connector currently, I know that this plug houses the battery, m-rel , and b.
I have also found those same wires on the factory harness for the Cressida and pulled them out of the ecu plug to wire into the e11.
My question is are those the only wires i need to hook up to make this engine run ?
Additionally , i know most of the wires for the batt and such are under the dash on the ls400, I believe that those same wires are on the Cressida are up by the fuse block under the hood.
IF anyone has done this swap before i could use a bit of advice ,
