C crazyeyes New Member Messages 3 Location Benoni Sep 22, 2012 #21 I think a similar base formula as Fopar on here might be the way to go he is getting 1200hp out of what is mostly a boosted stock engine http://lextreme.com/forums/showthread.php?t=13376
JustenGT8 New Member Messages 2,432 Location Canberra, Australia Sep 22, 2012 #22 crazyeyes said: I think a similar base formula as Fopar on here might be the way to go he is getting 1200hp out of what is mostly a boosted stock engine http://lextreme.com/forums/showthread.php?t=13376 Click to expand... Mostly stock? ORLY? It's about as built as you'd do a UZ......not that it isn't an impressive performer evn still.
XR8tt Active Member Messages 2,758 Location Sydney Australia Sep 23, 2012 #23 JustenGT8 said: Mostly stock? ORLY? It's about as built as you'd do a UZ......not that it isn't an impressive performer evn still. Click to expand... Not wrong !!! With a "burnout type engine" .. I would limit power to 7 to 800 h.p !! Should have enough torque ... Burnout engines need to be VERY durable .. Fit the BIGGEST cooling system you possibly can... Set rev limit and don't change it !!! Last edited: Sep 23, 2012
C crazyeyes New Member Messages 3 Location Benoni Sep 24, 2012 #24 JustenGT8 said: Mostly stock? ORLY? It's about as built as you'd do a UZ......not that it isn't an impressive performer evn still. Click to expand... stock block stock heads with work stock crank stock valves he just did cams rods pistons fueling boost that is impressive for what his achieved
JustenGT8 New Member Messages 2,432 Location Canberra, Australia Sep 24, 2012 #25 crazyeyes said: stock block stock heads with work stock crank stock valves he just did cams rods pistons fueling boost that is impressive for what his achieved Click to expand... LOL show me a built Toyota engine that doesn't use stock block and crank That's the biggest 'just' list I have ever seen. If there were less bits from Toyota it wouldn't actually be a 1UZ :tongue: Can't decide if you only have pushrods experience or no experience at all? And no one has said it's not impressive, quite the opposite...those guys know how to build engines no question.
ash New Member Messages 407 Location qld Sep 24, 2012 #26 JustenGT8 said: LOL show me a built Toyota engine that doesn't use stock block and crank That's the biggest 'just' list I have ever seen. If there were less bits from Toyota it wouldn't actually be a 1UZ :tongue: Can't decide if you only have pushrods experience or no experience at all? And no one has said it's not impressive, quite the opposite...those guys know how to build engines no question. Click to expand... Lol... Coughed out my coffee..
