Toyota Sequoia 2UZ-FE Engine Swap
PARTS FOR SALE: Limited availability on EGR Delete Kits, Torque Converters and Supercharger Brackets. No turbo kits. Email for info: [email protected]
Steedog
Mission, KS
I own a 2002 Toyota sequoia 4wd which I understand uses the 2UZ-FE, engine and has 240HP.
Now I know newer sequoias also use 2UZ-FE, so what kind of problems would I run into if I wanted to swap mine out for a 2UZ-FE with more HP.
Would a newer sequoia engine fit right in to my 2002, without any trouble? Also should I assume that the 1UR-FE and 3URFE would not work as well?
George_R
Well-Known Member
Russia, Moscow
loom won't plug it, immobilizer system is different, instrument panel / ABS / a/c interface is different
so it will be like swapping say F150 or RAM 1500 to said 2UZ
blackdemon_tt
I would suggest, look up the workshop book and see what needs to change, as the pins may be different, odds are you may be lucky and stuff might line up, but you will need to do work yourself to get everything right, if you have someone else do it, then, you may want to look at @George_R's signature, and come out the pockets.....
