SC470TT (VVTi)
Lextreme
Just call me "Lex"
Gents,
Got my 800 cc injectors today. They are direct bolt on. I will install this weekend I hope. I didnt want to mod any fuel parts so I was looking for direct drop in.
stevechumo
Gents,
880 cc injectors! That's almost double of my 460 cc injectors! Make sure your engine will double the hp of my engine. :D Nice...
spf_lexus
what fuel reg do u plan to run? AEM makes a 1000hp rated unit thats reasonably priced. btw, hows the final touches on 5.2 coming?
Lextreme
Just call me "Lex"
My wife still has 4 free tows left from AAA and I used two of them yesterday because our Auto Club Premier Membership expires in a week. Towed my car to a local muffler shop to connect and make some custom pipes and a dual cat (two in and two out 2.5") The front two cats were deleted and replaced with the mid cat. I don't have any pictures because I didn't pick up the car. I can take some pictures. Looks like few more things and then trying to book a time with a tuner to help me wire up the harness and standalone.
Things to do:
Shift Linkage
Alternator Mounting
Extend Secondary O2 Sensor Wires
Proper Serpertine Belt length
Wiring
Tune
Fire up.
Lextreme
Just call me "Lex"
Almost... trying to get it fire up before this year is officially over. This weekend will get really dirty....
Lextreme
Just call me "Lex"
Just want to give you guys some updates. Here is what has been done for the past week:
* VVTi Throttle cable installed (If you guys thinking about swap to VVTi motor, throttle cable is a must)
* Relocation of alternator with proper belt size along modified alternator harness
* Installed front bumper
Things to do:
* Upgrade to Supra MKIV TT 3 rows aluminum radiator. I got it from http://www.sonicmotor.com/category_s/4535.htm. Jim is the owner and extremely cool with 5 star service. Highly recommend this place.
The stock 95 SC400 has remote reservior tank and radiator cap. I am having trouble fitting it into the engine package. Too much work to mod, so I decided to get an upgrade and it has a build in radiator cap. Most aftermarket radiator doesnt come with cap, but Megan does. That itself save me at least $20-25 dollars already.
Since this radiator doesnt have intergrated transmission cooler, so I would need to get one seperately.
I will try to fire up the engine with stock ecu and maf and see if it would turn. Perhaps in a week or so. Here are some pictures
spf_lexus
She looks ready to pounce.... when does it get it's heart and brain wired up? Im guessing your down to the small tidbits of the build?
cribbj
"Supra" Moderator
Awesome progress there David. Can't wait to hear it run and see some dyno figures.
Looks like you may need some turbo heat shields or coatings....
Lextreme
Just call me "Lex"
John,
The pipes and turbo turbines are ceramic coated. However, if fund allow I would like to get a set of turbo blankets (turbo Sleeves). We will see. I spent another couple of hours install the new Megan 3 row radiator. Luckily the hose connections were direct fit. The bottom sitting is little different but still work out ok.
The reservior tank is current located on the right side near the headlight. So far that is the best place for it. The Megan MKIV radiator comes with 1.1 bar cap. Here are some pictures...
JBrady
Moderator
David, looking great. Looking forward to "hearing" it run!
Your alternator relocation is a nice piece of engineering. That said it is still something to work around and the heat from the turbos is a factor.
Idea: what about running an alternator with an SC400s hydraulic fan drive? I am unsure of the power capacity of the fan drive or the speeds available but it just might work. That would allow "alternate" alternator placement out of the way... heck nearly anywhere.
Lextreme
Just call me "Lex"
Thanks John. Are you saying to use the hydraulic pump to power the alternator?. So I would need two pumps. One from the engine and one to convert the hydraulic engine into rotational energy? Interesting idea.
stevechumo
David,
You'll also need to wrap up those turbos and pipings. The ceramic coating is for reducing the heat, but it's not for completely eliminating the heat. My single oven already causes me too much headache, and now you have two ovens. :eek: The heat will expand and cause more heat when it's trapped under the hood. It's just like virus until you suppress it.
Lextreme
Just call me "Lex"
Since the new Megan 3 row aluminum radiator doesnt has oil cooler. So I got an independent transmission oil cooler. I was debating where to put this 12 x 6 x 2 inhes. Some of the options wee behind the intercooler but somehow it just didnt work out. I test fit with the bump on and there is plenty of room for this oil cooler. The cooler is mounted to the front bumper beam and to the frame. Very stable. I need to get some custom made hoses with AN fittings. Noticed the cooler is mounted upside down. This configuration allows me to mount up higher for clearance and ease of access. Here are some pictures.
