Patrick Bateman
- 9
After many years of planning a 1UZ project, I've finally gotten around to doing it. I just needed to find the right car. I considered a number of smaller RWD Toyota vehicles to take the 1UZ and stay true to the brand... I even considered the Lexcen (google it)... but I've always been a fan of the E36 styling and the way they drive.
This forum has been a great help so far but most threads lack detail of how important problems were overcome or solved - they go from "A" to "C" without explaining the "B" - so I will try to detail every step I can so that anyone else considering this particular swap has a better starting point than me.
ENGINE: purchased a 1996 Soarer that had been 95% gutted for parts, except for the engine, trans, wiring and ECU. Fuel pump ECU was missing as was the AFM and intake. The motor started first kick and ran very well when loading the car onto the trailer... which in itself was a challenge. Air suspension valve body had been removed so ground clearance was a little over 1".
After stripping the motor, trans and electronics from the car, it has received a freshen up, consisting of:
VEHICLE: searched Sydney for several months looking for a cheap E36 in good condition but it turns out that is a paradox. I had to look interstate to find this 320i, It had a blown head gasket but that is irrelevant. Rolled the dice and purchased it sight-unseen. Turns out I was lucky this time. Apart from the interior looking a little tired and a matchbox-sized patch of rust under the battery, this car is mint.
- Hours of scrubbing and cleaning
- Water pump, cambelt, pulleys, bearings and seals
- Plugs, leads, rotors and dizzy caps
- Rocker cover gaskets
- Injectors flowed and tested
- All filters
