i had sent my box to mv auto over in SA, they done a semi manual kit with hd clutchs on my box and included a 3200 rpm stallie.
when in drive, it behaves like a normal box but has a quicker gear change in it, then you have the option off running it like a manual too 1,2,3 then OD
I am using a B&M rachet shifter with this setup.
Sorry to say, NO you cant bypass the electronics off the box, its part of the gear selection process off the gearbox
http://www.lextreme.com/forums/showthread.php?t=9814
[FONT="]:sgrin:There is No substitute for cubic inch, except for BOOST !!!![/FONT]:sgrin::burnout:
