oneeyefrail
can anyone point me in the right direction for a drawing that i can take to a engineering shop to make up the above or anywhere who sells these at a sensible price? thanks in advance
			I agree there has to be a way to make a drawing to have this piece water cut from a drawing. This piece that they are selling should be $200 tops.
BP
I think watercutting would be out of the question, it needs to be quite thick to make up the space needed. it seems machining on a mill is the only option. which amplifies the price.
water cut, yeah probably not. laser cut, definity. the laser that we have at work will cut metal over 1" thick. I think that it will cut up to 2" thick.
Jake, looking like I am going to have to borrow your R154 an do a drawing for it.
It wouldn't be an entire bellhousing, just an adapter to bolt the UZ auto bellhousing to the trans. I already have the adapter drawn for the W58 and the first prototype is built. Now its time to do one for the 154.
Now that looks the bizz! ed_ma61 is it posible to get a file I could give to the dude at the laser cutters? Or will I have to take the dimensions from my transmission and bellhousing ?
Indyman this adapter goes between a 1uz bellhousing and an R154 transmission. So you junk your R154 bellhousing, fit the adapter then the 1UZ bell then bolt the lot up to your 1uz block, Job n done.
I guess your thinking of an engine adapter plate to take an R154 bellhousing?
