Header Flange Drawings available for download!
Also please make sure your bolt holes are the right size...the flange I drawing is for 8 or 10mm holes..just need to re drill them the right size for your application..cheers
Hey guys,
i downloaded this .dxf file ages ago form somewhere on this site.
i e-mailed it to my local laser cutting dudes and hey presto:
Ive attached it to my post.
Ive really no idea where i found it.
but it works pretty sweet.
Daniel.
any info
Ill agree with that.
While not for metal working. There is an increasing number of small, low end (cheap) 2D & 3D router machines for wood working.
Better yet, the DIY CNC movement is finally taking hold. Lotta people are starting to use avalible parts, servos & controls. Software, free plans & materials to build their own CNC routers.
There have been afew people take things like the cheap $400-600 harbor freight mini mill, and convert it to servo drive without a software.
Neat things you can do for a grand, or so.
I've seen afew of the routers turned into plasma cutters too, but they start getting out of hand expencive for what most homebodies would ever do.
you have any more info on turning mini mill into a servo drive unit? this sound right up my alley...lol
As the file name would suggest 1.75inch is the ID
perfect for 38NB steam pipe. which is what i used
FYI is it a good idea to have a closer match to the ID of the port to the ID of your header.
having a large jump/step can cause turbulence.
Hole size is 1.75 inch, perfect for 1.25 inch NB steam pipe type welding elbows.
perfect for turbo headers made from steam pipe.
this time its a LJ78 landcruiser that is getting boosted. my aim is to be able to do 4x4 heli's in a landcruiser. watch for a vid in about 6 months time.
The flanges are made from 1/2 inch mild steel.
I used these same flanges on my supra with 4 into 1 steam pipe manifolds and T3/T4 turbo"s with 38mm waste-gates and i have had no leaks with these flanges, I reused the 18yo MLS gaskets that my engine came with.
2 years and 2000ks that my supra has been running. Often driven like I stole it:
Quick google came up with https://grabcad.com/library/1uzfe-header-flange-1
Any watercutter should be able to use this and modify to whatever format needed. Not sure of accuracy
If this does not help, I can draw up and post
What format are those in, Dave? If I could get this in AutoCAD or SolidWorks, I can try to start making the flange available at a real value again. I think David (Lextreme) has one left and that's it.
Not sure on format of these. Didn't look too much.
I'll fire up a solid works machine tomorrow and check the file. There is some intake drawings on cad grab. Not sure on what series they are though. I'll look at these same time.
I see there is so much good info on this site though so many broken links. Has the site had data issues in the past?
Ill put up .dxf tomorrow or Monday.
The Files on Cadgrab for me didn't work out, though attached is hopefully what everyone wants.
There is some difference in what I have here and the measurements that ludsonline has above. the exhaust port has a 3mm dicrapancy, this may be due to the fact of using a 1.5mm wall tube. This is where I see most projects differing a little on tubing selection and if the head has been ported out or shrinking/expanind tube to fit here.
none of these measurements have been verified agents a head (my project to far away to be looking at exhaust ATM)
