1UZ EGR delete - resistor install with 6-pin connector (temp sensor integrated?)
Lextreme
Administrator
Gents, trying to help a customer who deleted the EGR system on a '93 LS400 and is suddenly getting a CEL.
(click for larger image)
On the 25620-50020 EGR valve (for 93-94 SC400 or 92-95 LS400) with the 6-pin connector (pictured) is the temp sensor integrated into the valve? I'm familiar with the EGR valves with an external temp sensor, not this one.
It's the 6-pin connector EGR valve that seems to need resistance to clear the code. Unplug that connector and we get a CEL. He's plugged the EGR back in now but we need to figure out which contacts in the 6-pin connector need resistance.
We're stumped where to install a resistor.
Again, not certain if the temp sensor is integrated with this valve or there is an external one.
Here is a guy with the same 6-pin connector who says he has an external temp sensor: sc400 EGR DELETE --still throwing CEL code 71 - ClubLexus - Lexus Forum Discussion
And here you can see the part: 1993 Lexus LS400 EGR Valve Temperature Sensor - NGK EA0070
Any help? @gloverman @Zuffen Others?
I have the same issue with a 97 SC 400. If you take a meter and measure resistance on the six pin you will find that there is 22 ohms resistance from the center pin to the pin on either side of it and there are two rows of pins so upper row & lower row and they all come out 22 ohms. I'm going to run it by me buddy that's a wizard at auto electronics but I'm thinking 4 resistors at 22 ohms ea. Solder 2 on the center wire and connect to the 2 wires, one on each side of it x 2 rows. I'll post a follow up if this works
Please do!
Can you update on this?
Looked all over and can not find an external temp sensor for my 93 ls400
here is the egr that was removed
not sure what to do about getting rid of this 71 code and there was no egr vacuum modulator on the system.
Is the resistor installed? Would love to get an answer on this problem. Not sure why confusion abounds about the early models. Did something change mid-year?
Can anyone help?
Not sure where to put the resistor since there is no temp sensor on this car for the egr system would love to get this done now since we are currently getting up to 8"of snow plus here in Indiana and Trac control is off because of this!
Did you see this?
It blows me away that I've only heard of this twice in all of the '93 models I've sold kits for.
