cyberdiamond
1UZFE VVTi engine/trans harness/loom factory ECU, 5 speed Auto etc etc
Complete front cut with the engine, 5 speed auto including all the body looms fuse boxes and anything else you might want or need as I have kept it all. I have had the engine running and it ran well.
The ecu does NOT have the security inbuilt/enabled so you won't need to worry about ignition transponders, keys etc to get this running.
Although I do have the original keys, steering column and ignition barrel, dash etc if you want it.
I have spoken to companies that can wire this so it is plug and play for $650 - $950. Just send the loom out and get it back turn key for your conversion if you can't or don't want to do it yourself.
Will supply the factory manual that I ordered from Toyota for this as well.
Happy to put on a pallet and ship it to you cheaply.
