Standalone ECU 1UZFE 36-1 Trigger Wheel and Megasquirt
Are these still available?
What is the outer diameter? There are tons of wheels on ebai, diyauto tune, etc, but they come in different sizes?
Thanks.
Contact David (Lextreme). He may have some leftover from the last batch, or perhaps he could be persuaded to make another run if there's enough interest.
Ok not sure how much use this is to you guys but I have spent the day making up my own trigger wheel.
I started with a standard 100mm diameter wheel and merged it with the original 12 pointed 1UZ wheel and it went something like this
Perfect Power just confirmed that wheel is definitely for the UZ engines, and it comes with a spacer to give the correct offset.
The user simply has to grind off the appropriate tooth to get the 36-1 pattern.
what do you use if your switching to COP ?
ive got some nissan qg18de COP's and they look like they will fit.
Im an engineer but tbh electrics and management are all withcraft and magic to me !
i want to run MS3 with a cop arrangement is it capable of doing this ?
for me i am using a custom made grinded crank pulley into 36-1 trigger
and im running it with a wasted spark 8 COP and my MS1 v2.2
it works great
