Stock 1UZ @ 11.07 ET
Update,
Put 398 RwHp on Saturday night on 15.5 psi :)
That sounds about right. I think I'm at around 400rwhp. Made 350rwhp awhile back when I was trapping at 109mph, now usually around 115mph.
My best 1/4 to date is 12.047 @ 115mph (ish) in an SC400 that is a little bit more than 1000lbs heavier than your car.:p
Great job and good luck with the 10's hunt. Get that 60ft down a little.
KC
Neil is low on power on a very safe tune ;) I've seen the size of the turbo and it's good for better than 400rwhp on 16psi....best my twins have done to date is 445rwhp on 10-11psi. With a more aggressive (but still safe) tune he should get at least 450rwhp on 1 bar.....still, it does the numbers at the track and is safe so not like you wouldn't be happy :)
Great news, so I think Im on track because im also using the stock auto tranny like you and kc95sc400. I pushed out 312rwhp and 355rwtq at a mustang dyno, and my car weighs 2595 full trim. Once again great job.
Don't push any further with this auto tranny, unless you rebuild it with hi-performance kit. You're on the edge. Mine broke right at 334 rwhp and 371 rwtq after a week. I believe there're others running this complete stock tranny broke somewhere around there.
Neil uses some mutha of a Holset diesel truck turbine so gotta be 1.15 a/r at least is a T4 frame?
I use K26 housings (x2) on mine which are smallish so around a 0.6 a/r at a guess?
