The race truck is finished (knock on wood) and I have an all-day dyno  session booked for this Wednesday (March 5, 2010). I have installed a  smallish dry NOS set-up (one NOS fan nozzle + .021 flare jet in the  intake piping after the intercooler . . . and one NOS fan nozzle + .021  flare jet right after the supercharger). I also put a .061 flare jet for  each line at the NOS y-block to reduce the initial NOS surge at the hit  of the button.
I  will develop four O2-based maps from this session: (1) just the motor up  to 7000 rpm; (2) the motor plus the after-the-intercooler NOS nozzle  only; (3) the motor plus the at-the-supercharger nozzle only (more time  for the NOS to "exchange heat"), and; (4) the motor plus both NOS  nozzles.  My guesses are (at 6000 rpm): (1) 425-450rwhp, (2)  460-485rwhp, (3) 465-490rwhp, and (4) 530-555rwhp. Wish me luck. I plan  to use the NOS only for qualifying for "Top Truck" events with the AEM  turning on the NOS at 3700 and off at 5700 . .  and shift at 6200.
I have been in pretty steady contact with my shop guys and  although  the progress has been far from swift, it seems like all issues have been  sorted.  The starting and idling issues related to the fact that the  Subaru injectors DO FIT the 1UZ intake manifold, but they do not fit  well. .  . . the rubber swelling issue is prevalent no matter what gas  you use.  So, the fix is to make some small aluminum "washers" top and  bottom of the injector so that the rubbers are held firmly in place (the  lower washer) and also to make sure the injector does not get jammed  too far up into the fuel rail (the upper washer) to compress the rubbers  so they have no room to expand (like the standard 1UZ injectors).  I  discovered this from other 1UZ racers here.  What a hassle . . . but  necessary. They do not suck air around the injectors now . . . and they  will not allow boost to blow out either.  With that done the thing  starts up immediately, but still wouldn't idle below 2500 rpm . . .  what's up?  After a long search the throttle shaft of the throttle body  was found to be so loosely fitted that it sucked gobs of air in there. I  have  a better, high quality throttle body (80mm) to fit now.  These  little  details . . . flaws of quality, have cost me a lot of time. So now I am  only waiting for next Wednesday.
I got to worrying that my single Bosch fuel pump  would not be enough when I added a dry NOS jolt . . . and Jeg's was  having a sale on the Aeromotive A1000 FI fuel pump . . . . so I  ordered one with fittings.  The specs are great:
 A1000 (#11101) Specifications
 -10AN inlet and outlet
 Flows  700 lbs/hour @ 13.5 volts/45 psi
 Fuel injected engines:Up  to 1300 HP for naturally aspirated up   to 1000 HP for forced air  induction
As can be seen from the accompanying chart  (below), this  is a very good fuel pump which should provide me with adequate fuel  delivery for any future modifications up to 750+ horse power . . . . and  will have the volume when the NOS switch is thrown. I currently use one  040 Bosch.
