I recently replaced the antenna rod- still the original one but my FM reception is still bad. Is there a remedy? or do i have to change my radio? Thanks
Check for corrosion where the mast goes into the motor assembly. If that's OK Ohm check the coax from the radio to the antenna. If that is OK then you probably need an antenna assembly
