here i am again lookin for different possibility to get more power for my sc400. I've been doin alot of research on the 2uz block with 1uz head.
thought to myself if its possible why use a heavier 2uz block with 245hp/315 ft lb/tq from a tundra, when you can use the lighter 3uz which rate at 300hp/ and 325 ft lb/tq? wouldnt that be a better choice for running an N/A application?
well i see from the compatibility chart that the 3uz block is compatible with the 1uz block which mean the 3uz block will bolt up to the 1uz head
(please correct if i'm wrong).
So my question is, Is Using 3uz block with 1uz head possible for a sc400? and if its possible, what are the things that you would run into that need customization?
and how come i havent heard of anyone trying this process?
